Loft Conversion + Plywood Diaphragm
I am looking at a loft conversion. The new stairs will mean the removal of ceiling joints and a timber purlin spanning about 2.8m. The existing ceiling ties appear to counter act the horizontal trust at eaves level. I wany to fix deeper rafters to the existing and also form a diaphragm fixing a plywood deck to the underside of the rafters. This will be fixed to a ties rafter at each end, would this scheme be adequate to resist the trust at eaves?
RE: Loft Conversion + Plywood Diaphragm
Your calculations of forces and existing member and connection capacities will prove whether it is feasible and what needs to be reinforced. What do your calculations indicate?
