internal error : invalid solid object tag
I am new to this forum so I thought I would see if anyone could give me some a solution to this problem. When I try to save the part file I am currently working on I keep getting a error saying "save failed-internal error : invalid solid object tag" anyone have any ideas.
RE: internal error : invalid solid object tag
When this happens, I will sift through my features, deleting the latest one and trying to save until I find it.
Try that and let us know.
Justin Ackley
Designer
jackley@gmail.com
Ben Loosli
Sr IS Technologist
L-3 Communications
To rule out the specific part as a culprit, Suppress all the features and unsuppress all the features. This forces NX to rebuild the model. If it unsupresses without error you can hopefully rule out that specific model. Sometimes opening the part in a newer version of NX will clean it up with the suppress and unsuppress technique.
Examine geometry may help but it is mainly good for validating the model integrity not the file structure. Part cleanup may also be negligibly helpful since it deletes unused objects and duplicates mostly. All good techniques on their own but probably won't fix your invalid tag issue. I would try a patch to NX first.
-Dave
PLM Exchange
http://plmexchange.net
http://groups.google.com/group/NX_CAX/
