ASTM material cross reference
Is there any document(s) that lists each ASTM material number and defines the associated metallurgical content, intended use, manufacturing methods, etc? I've found a few nice websites here and there, but figured ASTM would likely have a document.
RE: ASTM material cross reference
h
What you are referring to is an Index of ASTM Standards. Correct?
A basic listing similar to something like the following is what I'm looking for:
http://www.howellpipe.com/howastmr.htm
I just thought there might be something similar available directly from ASTM that might be a little cleaner.
It may help to work backwards. If you are looking at steel pipe you can find all specs that refer to the general requirements (A450). They are listed in the GR spec. Specific alloys are only listed in product specs.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
http://www.matweb.com/index.asp?ckck=1
It's base listing is the UNS system, but there are then cross reference lists to ASTM, ANSI, etc.
Also, you should recall the basics behind ASTM numbers and UNS.
ASTM numbers are based primarily on mechanical property, whereas UNS is based on chemical composition. Hence, there isn't a straight one-for-one correlation.
