Wind Girders for API 650 floating roof tanks
What is the theory behind finding the Z (= modulus od resistance of the ring including tank shell contribution ...in in3 or cm3!!).
I mean if there is a (Z) then there is a bending moment.
How to find this Moment and the corresponding Shear Force ??
The reason I am asking this is: we want to use a wind girder with no web , instead we will use a sort of bracing or lattice to link one side of the Ring girder to to the tank wall...
And the question is how to size and check the lattice ?
I mean one has to reckon also with shear load and lnk structurally the two ring flanges !!
Thanks for your answer
RE: Wind Girders for API 650 floating roof tanks
Joe Tank
Just my opinion. I'm curious what others have to say about it.
A similar question comes up when superimposing dome roof loads onto the wind girder.
I would suggest to take the required section modulus, multiply by your estimation of an allowable stress, and take that as the designated API wind moment.
Lattice type windgirders were used (though not extensively) on open top tanks many years ago. The few that I have seen were on riveted tanks. Cost-wise, I have to believe that they are far more expensive thanplate type windgirders, primarlity due to the labor content.
Joe Tank
