Machine Dynamics: H factors
In order to calculate the longest fault clearance times permissible in an industrial power system I need 'stored energy constants' or H factors (in seconds) for the turboalternators. All machines are powered by 8,000 rpm steam turbines via gearboxes. These turbines are pass-out or non-condensing types supplying process steam in an aluminium refinery. The turboalternators are 50 Hz and as follows:
--   1500 rpm, 12 MVA turboalternator
--   1500 rpm, 20 MVA turboalternator
--   and 3000 rpm, 12 MVA turboalternator.
The H factor values need to include all of the rotating  components, that is, steam turbine, gearbox and alternator.
As an alternative to the H factor the moment of inertia, J in kg M², for each component of the drive train and the speed of each component of the drive train together with the alternator's MVA rating would suffice.
RE: Machine Dynamics: H factors
Please ask to the manufacturers of the alternators and the turbines.
Maybe look at the thread I asked about H values last week.  I got a very good answer from Marmite.
Basically you have the MVA and the speed and the H value is equal to 1/2Jw^2/MVA.  So you just need J.  you can look in the equipment spec's, ask the manufacturer or calculate it using for example J=1/2mr^2 for a disk.
Good luck.
Check the thread on : Hydropower Unit Inertia Requirement
