Elliptical gear tooth profile
I have been designing elliptical gears in Solid Works and have been using it without the use of gear trax. I have most of it completed but they do not mesh correctly. I believe it is because of the pitch addendum positions. I have seen many circular gear equations, and have modified them the best I can to suit me. Nonetheless they do not perfectly work. If anybody had some equations for elliptical gears I would like to know.
Thank You
Thank You
RE: Elliptical gear tooth profile
How are you going to manufacture them?
What do you mean by the "base width".
ANSI/AGMA 6123-B06, Design manual for enclosed epicyclic gear drives
