Unbelivable waste
Unbelivable waste
I know this has been discussed here before, perhaps many times, but I have to vent my anger ...
Assy1 is 1,733 kb. Now, use assy1 and make (higher) assy2 - assy2 contains ONLY assy1 and nothing else - after FIRST save assy2 is 3,193 kb. If I do NOTHING and just re-save assy2 I get 6,407 kb !!!
I know that even "empty" model/assy contains certain info so I could not expect to have size of an "empty" model to be zero or something like that. But this is a bad joke played by SW - 6407/1733 = 3.7 times the size of the assy1 file !!!
Now on the assy2 I add LPattern Number of Instances 2 and pattern that assy1 - assy2 size becomes 8,866 kb !!!
8866/1733 = 5.1 times the assy1 - just because assy1 is on assy2 and ONE linear pattern !!! And Pattern is suppose to be an efficient way of "copying" items.
Now make assy3 which uses just assy2 - after SECOND save the file size is 11,234 !!! That's 6.48 times of assy1 !!!
If on assy3 you use LPattern of assy2 (just 2 instances) the assy3 size becomes 16,138 kb !!!
Does anybody know if Solid Works folks have any shares in companies that produce hard disks ??
RE: Unbelivable waste
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
