Ni coating of steel from a Ni-solution
Hi everybody,
this is my first post here.
Could anyone help me with details about the type of conditions and start materials used to Ni-coat steel substrates from Ni-solutions ? The end result we get from one supplier in Spain is 18-20um thickness, a bright, smooth finish and a zero open porosity after coating.
We look for the type of solution commonly used and the parameter-values used during the coating process.
Thanks for any pointer you may give us.
Cedric Bhihe, PhD (alma mater: UCSB)
General Manager of the JV
Henan Inramik Xinji
People's Republic of China
RE: Ni coating of steel from a Ni-solution
The source in Spain consists of a vat containing the Ni-salt solution while an appropriate current is applied to the vat and steel part to be coated.
Cheers.
Henan Inramik Xinji
I entered the keywords "nickel plating" and found 133 feature articles with another 51 entries from Art Kushner's "Plating Clinic". The following is one example:
http://www.pfonline.com/articles/040102.html
Weren't you one of Tony Evans students? From France or Swizerland? What is JV (it usually means a junior varsity sports team in the US)?
This will help: 'Nickel Electroplating' from INCO.
http:
Maybe buy ASTM B689-97(2003), 'Standard Specification for Electroplated Engineering Nickel Coatings.' It gives quality requirements & tests for the electrodeposited nickel; doesn't tell how to do the plating although gives requirements for pre-plating stress relief & post-plating hydrogen bake-out based on the strength of steel being plated.
http:/
In Spain they maybe use ISO 4526:2004, 'Metallic coatings -- Electroplated coatings of nickel for engineering purposes,' but like the ASTM standard, this gives the required properties rather than tells how to do the plating.
http://is
Maybe also
ASTM B183-79(2004)e1 Standard Practice for Preparation of Low-Carbon Steel for Electroplating
and
ASTM B242-99(2004)e1 Standard Guide for Preparation of High-Carbon Steel for Electroplating.
Note: in these 2 guides, high-carbon indicates > 0.35 wt% C.
For setting up an electroplating line, best to get professional advice from the major nickel plating chemistry suppliers: Atotech, Chemetall, Enthone (Cookson Electronics), MacDermid, SurTec or Uyemura. All have branches in or near China. Using proprietary chemistry avoids many problems and gets you professional troubleshooting advice.
Good luck,
Ken
I found the answers you provided most helpful. I will follow your advice, Ken, and probably contract Uyemura out to set up my plating line in mainland China. Also would be happy to get in touch again after all those years (offline).
Btw, JV means "joint venture" between a chinese and foreign partner.
THREAD closed.
Thanks much to y'all.
Henan Inramik Xinji
Nickel Plating Handbook, 74 pages, very thorough w/o being too technical, many figures & photos, from OMG:
http:
