Viewport Toolbar
Viewport Toolbar
Viewport Toolbar
I cannot figure out how to find and dock my viewport toolbar.Any suggestions?
RE: Viewport Toolbar
Hi FishCAD,
which AC-version are you running?
Command: "_toolbar" -> check the toolbar...(for ADT2004)
Lothar
ADT 2004
ACAD 2002
Have you tried right-clicking on one of the visible toolbars; you should be able to check the Viewports to make it visible. If that doesn't work try using the -toolbar command (note hyphen). When asked for a name use Viewports. Next option use Float and use the defaults. It should show.
____________________
Acad2006, Terramodel
