SS diaphragms for pressure sensors
We are developing a small line of specialty pressure sensors. These are relatively small, and the diameters will be 2mm for one model, going up to 12mm for the largest. We are now at the tough part and thats designing a good diaphragm, and am looking for help. We can source the diaphragms or make them ourselves. Pressure ranges 0-15psi, 0-100psi, a very low pressure (1psi) and a high pressure unit. Temps will be nothing crazy: -20 to 150 C.
All sources, links, directions, suggestions, and warnings warmly welcomed.
dj
dj
RE: SS diaphragms for pressure sensors
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
doug
doug
Cory
These alloys are a little less stiff than stainless, but not bad. You can get tons of data from alloy producers such as Special Metals or Allegheny Ludlum.
Rust never sleeps
htt
Thanks everyone, we are launched.
doug
