SW materials
13
SW materials
RE: SW materials
Chris,
Thanks for the materials. Got a to look inside, you did a great job adding extra Alloy materials that SolidWorks does not have. Another star for you.
Bradley
SolidWorks 2007 SP2.2
NVIDIA Quadro FX 3400
RE: SW materials
This may be a dumb question, but how do you use it?  Do I rename it as "solidworks materials.sldmat" and put it in the ....lang\english\sldmaterials folder?  Or is it not a replacement for the existing one and I just point to it somehow in SW?
SW07 SP2.0
Flores
RE: SW materials
Just put it in the same place as the "solidworks materials.sldmat" or wherever your Tools > Options > System Options > File Locations > Material Databases points to. It will be available in the manager when selecting a material.
You can rename it to whatever you want, but it is an addition to the SW supplied file and should not replace it.
cheers
RE: SW materials
12
Thanks guys.
CBL is correct.
Sorry, I didn't have time to type an explanation earlier.
I would not replace the existing SW file, this one would be in addition to.
CBL a start for the help! ;)
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 01-18-07)
RE: SW materials
Chris,
Thanks for taking the time to create that material dbase.  That was on my "to do" list and now I can do something else.  A star for you 2thumbsup
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
RE: SW materials
Just as CBL stated Tools > Options > System Options > File Locations > *.sldmat.
When you go into the material editor you will be able to toggle from the default material dbase to Chris's material dbase.  I don't think you can delete the SWx default material dbase file.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
RE: SW materials
Cheers Dude, thanks for sharing that with everyone.
RE: SW materials
Much grass, man.  I might be making use of this quite soon.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
RE: SW materials
Thanks for your time and effort.  By the way, are you trying to make mvp on one post?  I don't think I've seen that many stars on one post before.
cheers
SW07 SP2.0
Flores
RE: SW materials
Does anybody know if you can take Chris's database and combine it with the existing SWX database file. I have not tried it yet, just wondering if anybody else has attempted it. Thanks Chris it will come in handy.
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
RE: SW materials
If you do edit the SolidWorks database, make sure you keep it safe on the network. The next new install will over write your database on C:\
Bradley
RE: SW materials
<<<<< MAKE A BACKUP COPY FIRST >>>>>
You might be able to open both up in Notepad and then cut and paste. But I don't recommend you do that as you will lose the modifications when you next upgrade.
It's very easy to use multiple Material Databases ... their really is no need to combine them.
cheers
RE: SW materials
I store all mine in a neutral location (file hard-drive instead of system drive), along with all custom PhotoWorks stuff, templates, etc.  So if I get a hosed installation (or system drive), all is still well--nothing lost that cannot be restored.
Jeff Mowry
RE: SW materials
Happy to help.
IMO, the more we help each other out, the better we get and the better the product gets from our input to SW.
Flores,
I just like purple stars.lol
Chris
AutoCAD 06
RE: SW materials
Has anyone ever noticed how the material editor totally trashes on your page file as you flip from material to material. It appears to be storing the texture info for each material in the PF but it doesn't let it go after you close the editor. The PF doesn't clear out until you close the part.
Expand all the materials and just start clicking down the list. If you don't have a big PF or much RAM get ready to crash as you move down the list.
RFUS
RE: SW materials
Oh yea.
thanks ctopher!
