Spring back rates for 316 SS
Does anyone have any data on spring back rates for 316 SS? I am trying to bend plates (approx 8" x 5" x 0.25") and in order to size the die correctly, I would like to factor in the spring back rate.
RE: Spring back rates for 316 SS
Bend radii, degree springback in a 90 degree bend
304 ss
1t 2 degrees
6t 4 degrees
20t 15 degrees
Also, springback is approximately proportional to the equation below;
(0.2YS + UTS)/2.
