center all dimensions
In SW 2007 SP2.1, is there a way to center all dimensions in a drawing without right clicking each one and going into the display options? Is this a document option? Is there a keyboard shortcut to do/not do this as I place the dimension?
Matt
RE: center all dimensions
Do a window-select and pick all of the dimensions.  Right-click one of the dimensions > Display Options > Center dimensions.
SW07 SP2.0
Flores
And for future dimensions select the Center between extension lines option in Tools > Options > Document Properties > Dimensions.
You can save drawing templates with that option selected and/or un-selected.
cheers
