How removing the sulfur in butane?
Dear everyone
In my crude distillation plant, butane is rundown through the MEROX system which is for removing sulfur contents in butane to pass the caustic extractor to make disulfide from hydrogen sulfide, and this disulfide(RSSR) is removed to be separated from caustic flow. By the way, if there is mono-sulfide(RSR) in crude oil originally , RSR is remained in butane finally because it is not to be reacted in that MEROX system, so it might be problem on the regulation of sulfur standard in butane. Could you let me know a way to remove sulfur contents of 40 ~ 80 ppm in butane?
Regards.
Regards.
RE: How removing the sulfur in butane?
