Post Builder - Tap Cycle
Hello friends,
  Now the NC data output of my post for all opeartion look like this,
G43Z50H01
S1000M3
G04X3
M8
G98G82Z-5R6F250K0
I am indeed of changing the sequence for Tap Cycle only like this
G43Z50H01
G04X3
M8
M29S1000
G98G84Z-5R6F250K0
Is this possible in the postBuilder? How can i find whether the operation is Tap Cycle or not ?
Please help me ASAP and briefly.
Kindest Regards,
Srinivasan C
Japan.
RE: Post Builder - Tap Cycle
Yes it is possible. You will need to use PostBuilder to customize the Tap Cycle command.
Ben Loosli
Sr IS Technologist
L-3 Communications
In Post Builder you can customize the Tapping cycle output.
From the general parameters activate the customize option for the tapping cycle.  Then edit the tapping cycle and add the S word and the M29
John Joyce
i Knowledge Solutions
www.myigetit.com
Thank you for your information. I have customized the TAP cycle and got the result like this
G43Z50H01
S1000M3 -- dont need this line
G04X3
M8
M29S1000
G98G84Z-5R6F250K0
In my post i have defined the Spindle speed and Spindle rotation in the Operation start sequence of Initial Move.
In the Tap Cycle How to skip the Usual output of Spindle speed and the rotation ?
Thank you in advance.
Kindest Regards,
Srinivasan C
Japan.
