Searching for Material that will cope with 2600F temp.
3
I work in a refinery that 'Roasts' ore. I am searching for a material that will cope with 2500 degF - 2700 degF temperature to use as our burner telltale tube. We had used 310 stainless steel but it could not cope with the constant high temperature. Can anyone recommend a material that we can source in a pipe shape that may cope under these conditions. Thanks.
RE: Searching for Material that will cope with 2600F temp.
There is no metal that will work. There may be a ceramic material that would work.
TZM (Titanium-Zirconium-Molybdenum alloy) is rated up to 1400°C - it may just work in your case.  One supplier is PLANSEE (see www.plansee.com)
Is pure tungsten not a candidate? Just curious.
I have used refractory metals, I would suggest that you look at ceramics.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Without coating the refractory metals will all oxidize at that temp. Diffusion coatings on refractory metals may provide the life expectancy required. These have been used in rocket engines.
I would go with Ed's advice and look at ceramics.
you will also need to characterize the hot gases' content of sulphur , sodium, mercury, etc since some of these elements  ( in a reducing atmosphere) may attack some ceramics.
Ceramics formed using Polysilazanes (an inorganic polymer) might be a way. I have seen some performance data at 1500C.
Try Kion Corp.
http://www.kioncorp.com/
They don't make ceramics, they make the silazane and can probably say one way or the other.
