Insert BMP, text hides behind object...
Ok...I looked quick but I couldn't find any fix or reason to the problem I am having. We use snapshots for representation of wiring configurations in our electro-mechanical assemblies. When a note or a note with a leader is used to define an object in the picture, the text hides behind the image. You click the image and select 'send to back' all is good...you now can see the text and leader. Save, close...bla, bla, bla. When the file is opened again, the picture is hiding the text like before. One other issue is it seems random...as in one file with the same pic will do this and another will not. Has anyone heard of this and how is it fixed? I have heard and read some of the problems with images in drawing files so I'll extend an invitation for humorous replies too
Edson Gebo
Mechanical Designer/Drafter
SW2007 SP2.0
Cadra 2006 (yup 2D still exists)
Sometimes Success Begins at Failure
RE: Insert BMP, text hides behind object...
Images are always on top of text in SWX (as far as I know).
So what I do is: add text to the image on an image editor.
Hopefully others may have better ideas.
As for humour, I looked at the CADRA website and they are 2.5D, that is right not 2D nor 3D but 2.5D
http://www.softech.com/products/cadra/
Best regards,
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 01-18-07)
ctopher...I know exactly what you mean but the drive is to make all (or most) info reside in a SW world. Eventually you won't see Cadra 2006 in my signature
Edson Gebo
SW2007 SP2.0
