CUT EXTRUDE FAILING
CUT EXTRUDE FAILING
I have a sketch on a flat surface. I'm trying to use this sketch to extrude a cut down from the flat surface .025. I'm getting a rebuild error that says " unable to create this extruded feature due to geometric conditions". The sketch is fully defined and is a closed sketch. The flat surface it is built on is .070 thick. I've used the "check sketch for feature" and there are no problems. Can't understand why the cut extrude won't work...seems simple enough.
any suggestions... ??
Thanks for the help.
John
John
RE: CUT EXTRUDE FAILING
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 01-18-07)
