Don't Have Any Fill Head on Steam Traps
I will be putting some steam reheat coils into ductwork that is supported right on the floor. This will leave me with no vertical head before my steam traps. I could run the piping over several feet (in one case probably as much as 100') and then drop down and put the traps there. But, is it a good idea to have so much piping between the coil and the trap? There is no other way to get head on the traps. Any ideas? Is there a style of trap that is more forgiving in this circumstance? Steam pressure is 15 psig entering the control valve. Condensate discharges to a vented tank with at most a 2' vertical rise from where the lower traps would be.
RE: Don't Have Any Fill Head on Steam Traps
http:/
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
http://w
Cheers
Luis
