Speeding Up Manipulation /w respect to constraints
Is there anything I can do to speed up the manupulation wrt(with respect to) constraints in and assembly.  My system bogs down and I the manipulation is delayed and choppy.  Any options or tips?  Thanks!
RE: Speeding Up Manipulation /w respect to constraints
If you need only few parts and the others only for visualization, you can put those parts which you don't need for work in visualization mode, or Deactivate Terminal Node (but you will not be able to see them until you will Activate Terminal Node again) or transform them in a cgr file...work with cache....
Fernando
I think Kinematic is faster for (manual) manipulation in some cases... but it needs to define join.
Eric N.
Hello
I've made a confusion, I was thingking to something else...big smile
Eric, you are right.
Fernando
