Equation Symbol Problem
Hello all
I received a new work computer with SolidWorks loaded. Now when I do an Equation, I get a ? mark instead of the Equation symbol. It is a simple equation Width divided by 2. I'm using SolidWorks 2005. Any options on why this is happening. Thank you.
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
RE: Equation Symbol Problem
I'm assuming the specs in your signature are for your old machine?
The specs in my signature are for my old machine. I'm going to update them later. In the Sketch beside the Dimension appears the Equation Symbol but with this new machine that symbol changed to a ? mark.
Cheers,
Ralph Wright, CSWP
P4, 2.53Ghz
1.5 Gb RAM
Windows 2000 Pro
Is this happening for all types of Equations?
New and existing?
The Equation functions properly when the associated dimensions change on old and new Equations. The Linked Values have the correct symbol attached to the Sketch Dimensions. In the Equation Box everything is OK, just the symbol that is attached to the Sketch Dimension is incorrect. Thanks for your help.
Cheers,
Ralph Wright, CSWP
Intel Pentium D, 3.2Ghz
2.0Gb RAM
nVidia Quadro Fx 1300 Card
Microsoft Windows XP Pro
The Linked Dimension symbol does show correctly. Just the Equation symbol is incorrect. The machine did go from Windows 2000 to Windows XP Pro. Thanks.
Cheers,
Ralph Wright, CSWP
2.0Gb RAM
