Sweeping a mesh in ABAQUS
Does anyone know how to sweep a mesh in ABAQUS?
Here's what I want to do, which I know you can do in ansys.
1. Create a quarter of a sphere.  Done.
2. Divide this in half.  Done
3. Partition one of the cut faces into smaller areas.  Done.
4. Mesh the partitioned face areas.
5. Sweep this mesh throughout the part.
I have tried to sweep the partition through the sphere and then mesh this, but I cannot get a symmetric pattern.  The end result is that one or the other halves has more elements even though I have specified the same number of elements for an identical line on each half.
RE: Sweeping a mesh in ABAQUS
Assuming that I've interpreted steps 1 and 2 correctly, Partition the face. Then choose Element shape = "Hex-dominant", technique = "Sweep" and Algorithm = "Advancing Front". Also, make sure the sweep direction is correct. This works for me...
That works!  Thanks.
