looking for worm gear
Hello everybody.
I'm trying to find a worm gear with that specifications:
- 300:1 reduction
- input rpm 2500
- output rpm 10
- output torque of 400 Nm
- No more than 15 lb
For having an idea for what i want that ->I will use it with a stepper motor for the controll of a micro wind tubine.
I'm getting crazy to find something which fits me but I don't find anything.
I saw something at http://www.dodge-pt.com, but I think the dimmensions are tooo big
Thanx for ur help!!
- 300:1 reduction
- input rpm 2500
- output rpm 10
Thanx for ur help!!
RE: looking for worm gear
The design will be governed by how long/strong a timing belt you can actually get. Be careful about designing in stuff that's in a catalog, but not in stock.
Mike Halloran
Pembroke Pines, FL, USA
Russell Giuliano
I don't need exactly an output velocity of 10 rpm because that is not very important for my project. some rpm up or down is ok. But what I need is the 400 Nm at the output.
I'd like to find something whith the house included. Without the weight limitation would it be possible to find something more easyly??
