Importance of Material Properties
I'm simulating the bending of a sheet of (amorphous, poly)silicon of ~300um in thickness.
Currently, I have the following material properties
density
young's modulus
poisson's ratio
I consider 2% strain the breaking point (my definition of "damage"), which can be obtained from LE (logarithmic Strain) or when it reaches the yield stress/strength.
I could also input yield strength and plastic strain, but if I did this, how would I know when the material has "yielded"? (when Mises reaches Yield strength?)
Is this considered "enough" to study the bending behavior of silicon? Which properties do you think are considered "minimum/essential" material properties? (I'm an electrical engineer, so I don't have too much insight in mechanical properties).
Thank you in advance.
RE: Importance of Material Properties
Besides Mises reaching the initial yield strength,
when material yields
- the components of the plastis strain (PE) tensor become non-zero.
- the equivalent (accumulated) plastic strain PEEQ becomes non-zero.
- the plastic dissipated energy ALLPD (in history) becomes non-zero
The material properties depend on the constitutive behavior (i.e. stress=function(strain, history parameters)) you want to use. In turn a specific constitutive behavior can be more or less suitable for a material.
