Center Feed Shell and Tube Exchanger
How would you go about designing a tubesheet that has a center feed pipe coming through? The tubesheet would be 24"OD and a 12-3/4"od hole surrounded by (196) 3/4"od holes.
RE: Center Feed Shell and Tube Exchanger
Mike
I'm desiging same kind of tubesheet, but the tubesheet OD is about 2000 mm and hole is 900 mm and there is hundreds of small (about 32 mm) heat exchanger pipes around central opening.
