Precast Tees - Topping Construction Joint Location?
When you have a construction joint in the topping over double tees (parallel to length of tees), what is the best location for the joint? (Center of tee, over tee stem, or at joint between tees?)
RE: Precast Tees - Topping Construction Joint Location?
When things are steep, remember to stay level-headed.
