Non bearing interior wall detail > 12'
Using 2003 IBC will a 13' tall interior non-bearing wall using the following material pass code?
1. Studs braced with 5/8 gyp board ea. side.
2. 25 ga 3 5/8 tract and stud.
3. Bracing @ 4'-0" O.C. staggered 3 5/8 25ga.
The 2 walls are for a restroom addition and are attached to an existing demising wall and exterior wall. Wall lengths are 7'2" and 6'4". Ceiling is 25ga 16" O.C. @ 8' with 5/8 gyp board.
Thanks in advance!!!!!
RE: Non bearing interior wall detail > 12'
There is a problem though if you are practicing out of your area of expertise, partiularly if you sign and seal this work. I hope that's not the case. It's hard to say with an interior non-load-bearing wall, but is it worth it in the end? I think it's worth having a professional check what you are doing. In the end it protects you, the client and your company.
