SPACEBALL 5000
SPACEBALL 5000
SPACEBALL 5000
Is there anyway that I can have a spaceball configuration set to a mode in Pro E(ie. modeling, drawing)???
RE: SPACEBALL 5000
In the configuration for the spaceball you should be able to store multiple configuration profiles.  i.e. drawing, part, assy mode.  There should a 3DxWare icon in your task bar area.  You'll have to make the switch manually but I believe you should be able to do it.
Fighter Pilot
Manufacturing Engineer
RE: SPACEBALL 5000
That I have. I wanted to know if it automatically would do it.
RE: SPACEBALL 5000
The newer SpacePilot automatically switches between configurations by application, don't know about by module. I guess I will have to hook it up and play with configurations.
Ben Loosli
Sr IS Technologist
L-3 Communications
