Draw Line Sumps
Draw Line Sumps
API 650 provides recommended draw line/sump size combinations but doesn't really elaborate on how these were derived. I understand that the sump should be of adequate depth to prevent the suction line from pulling air out of the tank, however, can anyone tell me of a quick way to check this or point me toward a good reference? My client is wanting to increase the diameter of a sump and reduce the depth, however the volume is also being reduced in the process. Would a vortex breaker be sufficient to handle the decreased depth?
RE: Draw Line Sumps
