Circular groove of variable depth
Hi guys,
Imagine you have a disk. On one of the faces you you need to put a circular groove, concentric with the disk, with a width from r1 to r2 (radius) and an angular length from ß1 to ß2 (angular). The trick is that the depth of this groove needs to be variable, like a swimming pool going from shallow (say 0 depth) to deep end.
Sorin
Sorin
RE: Circular groove of variable depth
http://
Image only;
http://img
Sorin
Just offering a potential alternative.
The required groove cross-section would obviously determine the actual machining and modelling method used.
Best Regards,
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he'
h
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
When I click on the link, it takes me to mooload.com, but then what?
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
