Drainage Ditch Sidewall Failure
Have poured approx 1200' paved ditch. All concrete/steel passed spec inspection. Large Paved area adjacent to 200'.
2 drain outlets from paved area about 30' from top of wall. Wall failed in this area (large longitudional crack @ approx. 3' up.) Wall 9' high on 1:1 (45 degree)slope. Fill material red clay. Compaction spec acheived. Significant rain event preceeded break. Remainder of wall no problem. Hydrologist suggests that either rain retained in equipment (Euclid trucks) ruts or equipment loads passing behind wall during construction are cause. Some agree, I doubt. Any ideas, suggestions,etc?
RE: Drainage Ditch Sidewall Failure
Was this wall designed for saturated clay, expansive clay?? Exactly what backfill condition assumed?
Is that 1:1 slope included in the wall design pressure
Any backfill drainage features included?
Does the design assume that upper paved area will be a waterproof roof?
Also what kind of country: arid, temperate, cold??
Good luck!
