Bray-Moss-Libby Model
Where can I find a simple description about Bray-Moss-Libby Model of Turbulent Combustion ?
Thank you.
Thank you.
RE: Bray-Moss-Libby Model
page 484 refers to "statistical model of Bray and Moss":
As we learned before from the previous discussion on premixed turbulent flames, there are two alternative hypotheses regarding the physical structure of a premixed turbulent flame:
A) Wrinkled-Laminar-Flame ... [description]
B) Distributed-Reaction ... [description]
It seems likely that, in different circumstances, each of these alternative models may have a region of validity. The purpose of Bray and Moss's work is to create a unified description of the premixed turbulent flame, in order to define these regions of validity and to bridge the gaps between these two hypotheses.
the above is followed by a somewhat lengthy discussion of the Bray - Moss model (about 9 pages).
If the Bray - Moss - Libby model is a modification of the aforementioned, you may have better luck finding info about it in an SAE paper or similar publication.
