Izo printing and hydrotest compliance in CII 5.00
Hy everyone!
I've just started using Caesar and I'd like if someone would help me with this first two questions:
1. I want to print the input izometric but in the centerline setting, the nodes appear to double themselves, the restrictions are too little to see and the image is too little in the middle of an A4 or A3 format.
Where can I find the settings for output izo printing?
2. I've inserted the hydrotest pressure and when I look in output,the code compliance isn't done and I don't know why. The sustained results are ok and code compliance too.
Thank you!
Best regards to all of you!
Thank you!
RE: Izo printing and hydrotest compliance in CII 5.00
1) I believe this problem has been fixed. If you're not running the 070122 build, donwload this to update your installation.
The other problem here is that you need to avoid using "PrintPreview". Unfortunately when you print from here the system pops the spreadsheet back, so the graphics are scaled to a much smaller region then you expect. Set the graphics up and print directly from the "File Menu".
2) Make sure "Sy" is defined in the "alloable dialog".
Richard Ay
COADE, Inc.
Thank you Richay for the valuable informations.
I've checked and all the problems are solved now.
I want to buy a good piping stress book. Can you indicate me a few good ones?
Thanks again.
A good day and best regards to all!
http://www.coade.com/support_reference.asp?varflag=Reference#4
Richard Ay
COADE, Inc.
Daniel I.
