Izo printing and hydrotest compliance in CII 5.00
Hy everyone!
I've just started using Caesar and I'd like if someone would help me with this first two questions:
1. I want to print the input izometric but in the centerline setting, the nodes appear to double themselves, the restrictions are too little to see and the image is too little in the middle of an A4 or A3 format.
Where can I find the settings for output izo printing?
2. I've inserted the hydrotest pressure and when I look in output,the code compliance isn't done and I don't know why. The sustained results are ok, and code compliance too.
Thank you!
Best regards to all of you!
Thank you!
