Positioning PCV on pump discharge line
I need information how to set and represent the control logic for positioning of Pressure Control Valve in pump discharge line on P&ID. The pump is pumping a seawater to be processed for well injection.
The pump discharge line is an 8" line discharging into a commom header of 20" line in parallel with 4 other pumps.
Thanks for anticipated cooperation.
RE: Positioning PCV on pump discharge line
The representation is identical to a FCV in the discharge line, instead of using a flow transmitter you have to use a pressure transmiter
regards,
roker
