file saving / purge
file saving / purge
file saving / purge
Hi All,
I am trying to find a way to be able to open a product/assy and save into a separate directory (on my hard drive) all the files used in that product.
Is there a way other than using the save management? - This is possible in other Systems.
Thanks - Kevin
RE: file saving / purge
Kevwoogs,
You can use FILE/SEND TO command
If you need new parts with the different UUIDs use FILE/NEW FROM.
Rgds,
Damir
Just what I was looking for!!
Kevwoogs - You can set your options to look in relative folder first, folder of link, folder of pointed document.
This will allow Catia to search the path of document load. For example: Offline the job folder from the server to a DVD disk.  you could put the disk into the dvd drive on another machine and load the part correctly.
Tools -> Options -> General -> Document.
Derek
Just be careful with the Search Order. Create one txt file (export from where Derek said) with your prefered paths where you are trying to open files and check it if its loaded when you need that order.
Fernando
