Hole table question
Hole table question
Hi all,
I want to create a hole table in sheet metal part. But when I select the coordinate system, the message say the coordinate system was incorrect. What does this mean?
I used the original default coordinate system & also tried to make a new one to do it, but with no success. Please help.
engmechs
engmechs
RE: Hole table question
I did the z axis aligned to the hole axis already. A message said no holes were detected. My model in question has a multiple 90 deg. bend and hte holes are located in one of the bended surface. I tried to put the coordinate system on the same surface, but still no luck. Please advise.
Thanks in advance.
engmechs
