F1554 Anchor Bolt Availability
I prefer using headed anchor bolts, but it seems that most vendors carry F1554 Gr 36 as hooked rods only. Does anyone know of a vendor in the Southeast that carries a good stock of F1554 headed anchor bolts? (I am trying to get away from A307 bolts, because too often the bolts are provided with a threaded length shorter than I would like for use with leveling nuts).
RE: F1554 Anchor Bolt Availability
