Large Diameter Tank Welding fixture / positioner
I am looking for names of companys that supply fixtures to hold/clamp two large diameter(90"plus)tank shells together so their circumferencial seams can be welded.  The fixtures can clamp either internaller or externally.
RE: Large Diameter Tank Welding fixture / positioner
Hi rbrez
Why don't you try a search?
regards
desertfox
Desertfox - I have been trying for about 3 hours with no success.   That is why I thought I would try this web site.
regards
rbrez
Desertfox - Thamk for the web site.  It is one of many that I had already went through already.  They do not have the equipment I am looking for.
rbrez
Hi rbrez
Sorry you already seen these people all I can suggest is you keep looking.
regards
desertfox
You should give these people a call.
There are places where you can rent/lease these clamps.
http://www.mathey.com/112.htm
You can try to go through the guys that make the welders, AstroArc, Arc Machines, and such.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
