Use of clad nozzles on an U stamped vessel
We are fabricating a carbon steel c/w stainless steel internal strip clad lined vessel which requires to be ASME 'U' stamped.
We are fitting nozzles complete with stainless steel overlay. We intend to purchase long weld kneck flanges and supply these to a sub-contractor to overlay for us, but they do not hold a 'U' stamp certification.
Is there any way that we can using this sub-contractor and still comply with the requirements of the ASME VIII code with out having to source an ASME autherised supplier?
RE: Use of clad nozzles on an U stamped vessel
