sheetmetal wall to funny angle - rectangular transition
This is hard to explain- please bear with me.
I have drawn a frame work for a sheet metal hopper with the top & bottom open, with a rectangular section at the top, sloping middle section and rectangular bottom section.
This is how:
1. create a plane on the middle trapezoidal section & create an 'unattached flat wall'
2. add 'flat wall' to top & bottom - this works ok I can modify the placement/shape/sketch and use the 'create an entity from an edge'button to tie the sketch to the original frame. ( the final stage is to alter the frame dimensions and recreate sheet metal flat pattens for any hopper size).
3. the bad bit.
trying to add a flange to sloping side of the trapezium;
using the add flat wall, placement/shape/sketch and use the 'create an entity from an edge' button- I can create the wall but cannot tie in the angle to the frame work which i want to use to drive future configurations. i can get by for a 1 off using this but i have to measure the angle then manually input the angle into the shape tab.
I have tried using the add flange wall, which works for edges where there is a square plane to reference the flange angle, but with the edge of the trapezium being at a 'funny' angle the sketch doesn't work out.
thankyou for reading this far.
This is how:
3. the bad bit.
RE: sheetmetal wall to funny angle - rectangular transition
for pictures go to :
http://www.youtube.com/watch?v=TAQBNloZYCs
Tags: wildfire 3.0 pro eng
sheet_metal_hopper
Cheers
