Old H Series Bar Joists
I have an old H series joist that I need some numbers on. The Bethlehem Old Joist tables that are downloadable do not go up to the joist I have.
I have a Macomber V-Beam 26H. Serial No. is C 67156E.
The tables in Bethlehem only go to 24H series.
Anyone have load tables for Macomber 26H's or even 26H's in general?
RE: Old H Series Bar Joists
I know the above isn't much help...I've even mis-placed the load tables that I received.
YOu are 100% correct about the top and bottom chords. Like a heavy gage plate bent in a sort of W shape.
http://revobiz.dyndns.org/group/seaint/2001c/msg00527.html
http://revobiz.dyndns.org/group/seaint/2001c/msg00530.html
http://revobiz.dyndns.org/group/seaint/2001c/msg01539.html
Perhaps if you contact these engineers they can help you out.
