Windows Vista & Pro E
Just something I saw on the web today
http://go.cadwire.net/?52628,1,1
85% slower for ProE, but just take a look at UGS.
Yet again it looks like Microsoft has failed to impress the world.
Kevin Hammond
Mechanical Design Engineer
Derbyshire, UK
RE: Windows Vista & Pro E
Lets be honest, all the big boys are already tied into Microsoft, whats the point
Kevin Hammond
Derbyshire, UK
Ben Loosli
Sr IS Technologist
L-3 Communications
That's a bit of welcome news. I was a bit worried about changes that are proposed for the company that I am with at the moment. I'll chat to the IT guys and tell them this bit of info.
Actually, just to enquire, was that on PTC's site or was that heard on the wires
Cheers
Kevin Hammond
Derbyshire, UK
Any help would be appreciated. I am wthout ProE and I need it desperately.
Ben Loosli
Sr IS Technologist
L-3 Communications
You will most likely need a newer version for Vista.
Ben Loosli
Sr IS Technologist
L-3 Communications
I've had many random issues getting things to work in Vista which generally all amount to it's new way of handling permissions. Go into your program files folder on whatever drive you installed it (probably C:\Program Files\)
then go into the "flexnet" folder and then the "bin" folder.
Generally, if you're having trouble running or installing something. Right click on whatever it is, and choose "run as administrator." Do the same for the file: ptcstartserver.bat
That bat file will launch the FLEXLM license server, and it needs administrator permissions to run. Hopefully that solves your problem.
