background colour in images
Hi!
I use Patran in a PC
I need take some images in Patran of results and I´d like that the background colour is white.
RE: background colour in images
Cant remember the correct way to carry this out, as it involved some PC work and i have had to much wine!!
There is a file/folder which needs to be in the same directory as the base files, this creates a toggle button in patran which allows black/white conversion. Might be linked to the same files as the utilities menu.
Sorry couldn't be much help, at home.
Will send the correct details on monday.
I had forgotton about this thread. Let me know your email address and i will send you some files and instructions as to how to change the background screen between white and black by the addition of 2 buttons within Patran.
You can also then subsequently make things clearer by changing the light colour source.
You can also do all this manually within Patran but again too many glasses of wine....
Let me know if you still want me to send you details, or tell you how to change it manually.
