shaft design
shaft design
shaft design
Please help in the dynamic analyis of force  and design of shaft for the vertical axis rotation of generator with the stator(2kg) and rotor(5 kg) component.
RE: shaft design
You might have better luck posting this in a different forum than the 'Piping & fluid mechanics' forum. Might try the 'Mechanical engineering other topics' forum or look at the forum index for a more subject related forum.
Good luck,
NozzleTwister
Houston, Texas
