Power train
Power train
I have specified bearing fits in accordance with the fits recommended by the SKF catalogue. The housing I am using is made of aluminium alloy to material specification LM27
The bore & shaft dimensions are as follow:
housing bore dia tolerance
1) 80 K7
2) 52 K7
3) 47 K7
Shaft dia tolerance
1) 20 k5
2) 25 k5
3) 40 k5
Pl through light on whether I should go by the tolerance specified in the catalogue. If I catalogue tolerance is used, the gear set is producing noise.
I tried to tighten the tolerance using m6 fit on shafts. I can find there is considerable reduction in noise. Is it correct to give m6 in violation of the tolerance specified in the catalogue?
1) 80 K7
2) 52 K7
3) 47 K7
Shaft dia tolerance
1) 20 k5
2) 25 k5
3) 40 k5
