Single Conductor XLPE MV Termination
Our QC have questioned the use of the mechanical roll spring steel placed around the Earth Tape Shield. QC have found that the roll spring is magnetic and are questioning the use. I say is doesnt matter as the roll spring creates a laminated installation and will not cause overheating. On all the kits I have encountered I never had this question raised regarding the effect of this roll spring being magnetic. These roll springs are supplied by Raychem and I am sure this would have raised questions in the past. I am in Kazakhstan and it is difficult to contact Raychem. However if anyone out there knows of any issues regarding this type of termination. I would be greatful for any info.
It seems that one encounters questions never asked before and it is becoming difficult to prove that what we have done for years is now questionable.
RE: Single Conductor XLPE MV Termination
Marmite
http://en
Select your type, the test reports are available for each at the bottom.
Good Luck!
