Aluminized Steel
Aluminized Steel
Aluminized Steel
I think that we can join this material with regular mild steel mig wire. Example E70s-2 in G.M.A.W. process. I can't find any info to prove this. The company is now using 309 sst. filler that is causing many leaks in the tank of the product. The base materal is regular steel alun. diped. If we went to steel filler the leaks would stop I think. The company we make this for wants to reduce corrosion with out going to sst. material. I need somthing in writing to show my boss.
