Enabling Measuring Tool on eDrawings
I'm having trouble enabling the measuring tool on eDrawings. When I save a Solid Works file as an eDrawing, I click on Options and enable the measurement tool but when I open eDrawings it still doesn't allow me to take a measurement.
Any solutions?
Any solutions?
RE: Enabling Measuring Tool on eDrawings
After that, the toolbar button remembers the Options settings and works great until I want to change the options back to disable measure or disable export to STL format, etc.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
If you do have Pro, then after you create the eDrawing, open the file and look for a button called 'Simple UI' or something like that. Toggle it back and forth and see if the Measurement becaome available then.
Ken
Jeff Mowry
http://solidworks.com/pages/products/3dmech.html
Cole M
CSWP, CSWST, CSWI, CPDM
SW06
SW07
IBM T42p, 2g proc., 1g RAM,ATI Mobility Fire GL T2
HP XW4100, 3g proc., 3g RAM, Nvidia Quadro 980 XGL
HP XW4300, 3.4g proc, 2.5g RAM, ATI Fire GL 3100
The measure option remains greyed out.
http
Is the enable measure option greyed out in the "save as" options when you save the edrawing from the original SW part or just when you open it in edrawings?
Cole M
SW06
SW07
Cole M
SW06
SW07
Jeff Mowry
http:/
Jeff Mowry
