$STATE@Hole1
$STATE@Hole1
SW2006 SP 5.0
Two configurations of the same part - one with hole and one without.
Now I am making "tabulated" drawing and one column will be: "Hole Exists" and the row below should have either YES or NO.
I have made "automatically populated" Design Table and it has column $STATE@Hole1 and below for config1 S (suppressed) and for config2 U (unsuppressed).
I am unable to somehow "grab" that info from the DT and use it in "general Table" on the drawing.
Next step would be to "translate" U into YES and S into NO, but I thing I could probably do it using equations (IF ...).
But going back to step 1 - how to "grab" that $STATE info from DT ??
I did search on the forum but found nothing (thou I am not very good at that)
Thanks for replies.
Thanks for replies.
RE: $STATE@Hole1
2) You could insert the design table into your drawing (formatted nice of course).
SA
RE: $STATE@Hole1
Search the Help file for Displaying a Design Table in a Drawing
RE: $STATE@Hole1
Wow - works like a charm.
Now, what's that:
Please explain like for a dummy ...
RE: $STATE@Hole1
The property SolidAir was referring to was probably a YES or NO comment.
RE: $STATE@Hole1
SA
